There's designer protection available out there for your favorite gadgets. As you are about to see
UGLY comes in small packages, and the Apple Tax is alive and well.
MoschinoMoschino's offering to the world of designer iPhone and iPad cases includes the Touch Me printed iPad 2 case. Available from Luisviaroma, the bright red and boldly printed cover is suitable for the iPad 2 model, and measures 24.5cm H x 19cm W.
This iPad case is priced at £41 ($63).
Via:
LuisviaromaThe Grove Bamboo iPhone 5 case The Grove Bamboo iPhone 5 case, crafted from renewable bamboo, is sanded by hand and polished with citrus oil. A "solid surface material" underneath the case is meant to protect your gadget from accidental damage.
Each case can either be ordered as a plain version or engraved with a number of symbols and patterns.
The Grove Bamboo iPhone 5 case can be ordered for $79.
Via:
GrovemadeHard Graft's skinny fit iPhone 5 caseHard Graft's #OldFashioned collection includes a case suitable for the iPhone 5.
The owner says that the vegetable tanned Italian leather, small gold logo and red and white ribbon are meant to create a fresh and quality feel. The case develops a caramel tint the more it is exposed to sunlight, measures 14.5cm x 7cm, and has subtle slots for credit cards as well as an opening for your headphones. The case is lined in Italian wool.
The case is priced at £82 ($125).
Via:
Hard GraftStella McCartneyDesigned by Stella McCartney, the Falabella faux brushed-leather iPhone 4 sleeve is trimmed with a chain in a gold tone and, naturally, comes with a designer hanging tag so you can make sure everyone knows it is a high-end product.
Compatible with both the iPhone 4 and iPhone 4S, this iPhone sleeve will only set you back £165 ($253).
Via:
Net-a-PorterFendiAs part of Fendi's 2012/13 Autumn Winter collection, a number of products appeared on the catwalk which appear to be handbags, but are actually hand-held iPad cases. The collection is made of designs from leather, tapestry, furs and skins in hard frames complete with handles -- and the bill for one of them is likely to make your eyes water.
Via:
HomeKlondlike.com]GucciMade in Italy, Gucci's blue crocodile iPad 2 case has been fashioned with a blue leather trim, palladium hardware and hook-and-loop closures at the top to keep your gadget secure.
The iPad case is able to fit all iPad models currently on the market, sized at 15.7"W x 9.7"H when open, and 8.5"W x 9.7"H x 1"D closed.
This iPad case is
priced at $3450.
Via:
GucciStella McCartneyStella McCartney's holographic faux leather iPad sleeve isn't to everyone's taste, but if you are a fan of metallic material, this holographic sleeve could be a fun buy.
This iPad case is priced at £145 ($223).
Via:
Net-a-PorterTaktik Extreme 5The Taktik Extreme 5, suitable for use with the iPhone 5, is designed with the adventurous type in mind.
Gorilla Glass has been used for additional screen protection -- without affecting touchscreen responses -- and the case is touted as a way to prevent both dust ingression and as a way to keep your smartphone safe from damage due to water.
Available in black or white, the case is priced at $124.95.
Via:
LunatikNancy GonzalezNancy Gonzalez's crocodile iPad case is a pink and girly accessory to protect your mobile gadget. Made from crocodile skin, the iPad case is compatible with all iPad models, and measures in at 8"W x 10"H.
However, it won't be a cheap buy, as this iPad case is
priced at £2,205 ($3393).
Via:
Net-a-PorterTyler, Jimmy ChooThe Tyler iPad case, complete with signature Jimmy Choo star hardware and detail, is made of calf leather tanned black.
The silver stars add a modern age to the case, and there is also a matching handbag available. The iPad case measures in at L21 x H26x W0.5cm.
The iPad case is priced at £295 ($454).
Via:
Jimmy ChooChristian LouboutinMade in Italy, Christian Louboutin's Cris Calf Spikes iPad case is available in black or in black and silver, and could go well with a pair of the designer's iconic spiked heels (complete with red soles, of course.)
This iPad case is priced at £483 ($743).
Via:
LuisaviaromaGucciA different style than Gucci's blue crocodile iPad case, the brown version is made in crocodile skin and includes brown leather detail and the iconic Gucci trademark. Made in Italy, this variation has a zip closure close to the handle, and also comes with 12 card slots.
Open, the iPad case's measurements stand at 18.5"W x 11"H, and closed are 9"W x 11"H x 1.2"D.
This iPad case is
priced at $5700.
Via:
GucciMulberryThis iPhone 5 cover from designer brand Mulberry is simplistic and lacks the fuss, sequins and flashy color of other luxury cases. The unfussy but classy cover features an embossed Mulberry tree in hard wearing leather.
The Mulbery case is priced at £90 ($138)
Via:
John LewisThe Little Pocket BookThe Little Pocket Book for iPhone 5 allows you to double protection for your gadget with space to stash away money or credit cards. Complete with a hand-stitched leather cover and available in a range of colors, the case also includes a wood frame made of baltic birch to help protect your iPhone from accidental drops.
The case allows you to access all device ports including charging and headphone jacks.
The Little Pocket Book is priced at $59.99.
Via:
Pad and QuillGressoGresso's Titanium Black case for the iPhone 5 is made of titanium and comes with a black PVD coating for a distinct, glossy black color. Protecting your iPhone from damage to each side as well as dust and scratches, the titanium cover is as strong as steel and is resistant to sunlight, corrosion and moisture.
The case weighs 35 grams and is highlighted with a 'Gresso' engraving.
The luxury case looks good but is only for those with deep pockets, as you can
expect to pay $1000.
Via:
GressoThe EXO16The EXO16 Black Aluminum Zircote Composite iPhone case is some of the strongest protection out there for your gadget. The cover is made of a strong phenolic resin composite core, capped at each end with Anodized Aluminum to prevent accidental drop damage.
For further protection, the EXO16 is held together with four stainless steel screws, which need to be removed to take off the case.
The price of each case is $230. A custom engraving can be added for $40.
Via:
ExovaultFor fun: Forget stars, spikes and leather, go for bacon.As a bonus, if you've had your fill of fur and crocodile skin, one designer hosted on Etsy has come up with an iPad case design that panders to lovers of bacon.
The Bacon Case is handmade, and as such is created to specifications based on which model you own. From a Macbook to the new iPad or iPad Mini, this weird but cool accessory is fashioned from wool, felt and olive soap.
This iPad case is priced at £46 ($70).
Via:
Etsy
