Author Topic: Microsoft rolls out new firmware updates for Surface Pro 4 and Surface Book  (Read 175 times)
A fresh set of firmware updates are now rolling out to the Surface Book and Surface Pro 4.
If you're using a Surface Pro 4 or Surface Book, you'll want to check for some updates. Microsoft has started rolling out a fresh batch of firmware updates to both devices, largely focused on increasing camera stability.
Here's a look at all of what's new, according to Microsofts Surface Update History:
Surface Pro 4
Surface Embedded Controller Firmware – Firmware: 103.1791.258.0 Improves device reliability.
Intel(R) AVStream Camera 2500 – Sound, video and GC: 30.15063.10999.4731 Improves camera stability.
Microsoft Camera Front – System device: 30.15063.10999.4731 Improves camera stability.
Microsoft Camera IR Front – System device: 30.15063.10999.4731 Improves camera stability.
Intel(R) Control Logic – System device: 30.15063.10999.4731 Improves camera stability.
Intel(R) CSI2 Host Controller – System device: 30.15063.10999.4731 Improves camera stability.
Intel(R) Imaging Signal Processor 2500 – System device: 30.15063.10999.4731 Improves camera stability.
Microsoft Camera Rear – System device: 30.15063.10999.4731 Improves camera stability.
Surface Camera Windows Hello – System device: 1.0.85.1 Improves camera stability.
Surface Integration – System device: 1.0.170.0 Improves device reliability.
Surface Book
The updates for both devices are tagged with an October 11 release date, so it's possible that they've already hit your device. If you're using a Surface Pro 4 or Surface Book, you can check for these updates manually now via Windows Update.
