Since this month's Patch Tuesday, Microsoft has released cumulative updates for every supported version of Windows 10 except for the newest one, version 1903. That changes today, as the company released a cumulative update for version 1903.
Those on the Windows 10 May 2019 Update will get KB4505903, and that will bring the build number to 18362.267. You can manually download it here, and these are the highlights:
Updates an issue that prevents Windows Hello face recognition from working after you restart a device.
Allows Microsoft Edge to print PDF documents that contain landscape and portrait-oriented pages correctly.
Allows Microsoft Edge to open PDFs that are configured to be opened only once correctly.
Updates an issue that may display colors incorrectly when viewing an image on a 10-bit display
panels.
Updates an issue that may prevent you from changing the display brightness after your device
resumes from Sleep or Hibernation.
Updates an issue that may prevent a device from going to Sleep mode when some applications that
rely on Bluetooth are open.
Improves Bluetooth audio quality when using certain audio profiles for extended periods.
Improves compatibility with the Window-Eyes screen reader application.
Ensures that the Start menu works as expected when new users sign in to Windows.
Updates the Windows Ink Workspace by simplifying the menu and adding direct integration with the
Microsoft Whiteboard app for a richer collaboration experience.
Here's the full list of fixes: Addresses an issue that fails to record a local users last sign-in time even when the user has
accessed the servers network share.
Addresses an issue that may sever the domain trust relationship when you enable Recycle Bin in the
domain that established the trust relationship.
Addresses an issue that prevents Windows Hello face authentication from working after a restart.
Updates time zone information for Brazil.
Addresses an issue to enable Microsoft Edge to print PDF documents that contain landscape and
Addresses an issue with PDFs that are configured to be opened only once in Microsoft Edge.
Addresses an issue that may display colors incorrectly when viewing an image on a 10-bit display
panels.
Addresses an issue that may prevent you from changing the display brightness when using certain
graphics drivers after resuming from Sleep or Hibernation.
Addresses an issue in which Windows Graphics Device Interface (GDI+) returns an empty font
family name for Bahnschrift.ttf.
Addresses an issue that may cause a mouse press and release event to sometimes produce an extra
mouse move event.
Addresses an issue that may cause the UI to stop responding for several seconds when scrolling in
windows that have many child windows.
Addresses an issue that fails to bypass automatic sign in (Autologon) when you press and hold the
Shift key during startup.
Addresses an issue that may prevent a device from going to Sleep mode when certain applications
that rely on Bluetooth are open.
Addresses an issue that may reduce Bluetooth audio quality when using certain audio profiles for
extended periods.
Addresses an issue that prevents Microsoft Application Virtualization (App-V) scripting from working
if you run it when youre not connected to a domain controller (DC). App-V scripting also fails when
you run it in an environment that only contains Microsoft Azure Active Directory.
Addresses an issue that causes an error if you open Microsoft OneDrive files on demand when User
Experience Virtualization (UE-V) is enabled. To apply this solution, set the following DWORD to 1:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\UEV\ Agent\Configuration\ApplyExplorerCompatFix
Addresses an issue with UE-V that may sometimes prevent exclusion paths from working.
Addresses an issue that may cause a system that has a Trusted Platform Module (TPM) to stop
working.
Addresses an issue that prevents a system from recognizing a Microsoft account or Azure Active
Directory account until the user signs out and signs in again.
Addresses an issue that may prevent the Netlogon service from establishing a secure channel and
reports the error, 0xC000007A ERROR_PROC_NOT_FOUND.
Addresses an issue that fails to update the personal identification number (PIN) policy (minimum
length required digits and special characters, etc.) for Windows Hello for Business when a PIN
already exists on the machine.
Addresses an issue that causes failures to create a recovery drive (USB key) with the error,
0x80042405[gle=0x00000715].
Addresses an issue that prevents an Android emulator based on the virtual machine platform from
starting on some systems.
Addresses an issue that uses a temporary profile to sign in a local user account when the account is
configured with a mandatory roaming user profile. The error, We cant sign in to your account
appears. The Application event log contains Event 1521, and the events source is listed as the
Microsoft-Windows-User Profiles Service.
Addresses an issue that changes the status for Work Folders in File Explorer to 0x80C802A0
(ECS_E_SYNC_UPLOAD_PLACEHOLDER_FAILURE) after selecting Free up space.
Addresses an issue that may cause a Remote Desktop Server to stop responding when someone
who is using drive redirection disconnects?
Addresses an issue that may cause the Remote Access Connection Manager (RASMAN) service to
stop working. You may receive the error 0xc0000005 on devices that have the diagnostic data
level manually configured to the non-default setting of 0. You may also receive an error in the
Application section of Windows Logs in Event Viewer with Event ID 1000 referencing
svchost.exe_RasMan and rasman.dll. This issue only occurs when a virtual private network
(VPN) profile is configured as an Always On VPN (AOVPN) connection with or without a device
tunnel.
Addresses an issue that causes applications on a container host to intermittently lose connectivity
because of a port conflict with applications running on a container.<
Addresses an issue that intermittently prevents connections to a corporate network when using
Always On VPN with the IKEv2 protocol. Connections are not always automatically established, and
manual connections sometimes fail. In this scenario, when you call the RasDial function from the
command line for the target VPN connection, you receive the error,
ERROR_PORT_NOT_AVAILABLE(633).
Adds limited support for Windows voice dictation for Chinese Simplified, English (Australia, Canada,
India, United Kingdom), French (France), German (Germany), Italian (Italy), Portuguese (Brazil),
and Spanish (Mexico, Spain).
Addresses an issue with opening or using the Window-Eyes screen reader application that may
result in an error and prevent some features from functioning as expected.
Addresses an issue that prevents an App-V application from opening and displays a network failure
error. This issue occurs under certain circumstances, such as when a system's battery is low or
there is an unexpected power failure.
Addresses an issue that prevents an App-V application from opening if the client is offline and
the startup script is defined for the App-V application.
Addresses a rare issue that causes Windows Defender Advanced Threat Protection (ATP) to
temporarily prevent other processes from accessing files.
Addresses an issue that causes the Start menu to stop responding when new users sign in to
Windows 10, version 1903.
There are also some known issues to be aware of:If this is similar to the update that was being tested in the Release Preview ring, then it will also hide Edge Spartan if you have Edge Chromium installed.
As usual, this is an optional update. That's true of all cumulative updates that ship on a day that's not Patch Tuesday. If you check Windows Update, you'll see a 'Download and install' button for it. If you choose not to take it, then these fixes will be bundled into next month's Patch Tuesday update.
