Author Topic: Windows 10 1909(November 2019 Update) is available via Windows 10 Update  (Read 112 times)
Microsoft recently released its second and last major Windows 10 update of 2019. Dubbed Windows 10 November 2019 Update, it’s now available for pretty much all the Windows 10 users via Windows update.
However, for those who haven’t receive the latest Windows 10 update via Windows update, Microsoft gives you various alternate methods to download and install all the major Windows 10 update and that eliminates the need for you to wait until the update shows up in Windows update.
And now the good news is Windows 10 November 2019 Update or Windows 10 1909 is now available via Windows Update Assistant, which is one of the most popular alternatives to the Windows update. In other words, Windows 10 users will now be able to update to the latest Windows 10 November 2019 Update via Windows 10 Update Assistant tool. You can download the Windows Update Assistant tool from this link.
After downloading the tool, you’ll need to launch it and then it’ll check whether or not your PC meets the eligibility to run the latest update. If it finds no issue, it’ll proceed to the next step and will start downloading the update.
Windows Update Assistant won’t interrupt your workflow while downloading the update, meaning that you’ll be able to minimize the update window and continue working on whatever you’re working on. Once the tool finishes the download, you can either install the update or schedule it.
Alternatively, you can also update to the latest Windows 10 update via the Media Creation tool. You can download the tool from here.
