Realtek fixed a security vulnerability discovered in the Realtek HD Audio Driver Package that could allow potential attackers to gain persistence, plant malware, and evade detection on unpatched Windows systems.
The Realtek High Definition Audio Driver is installed on Windows computers that come with Realtek audio cards. The bug was reported to the vendor on July 10, 2019, and it received a patch on December 13, 2019.
Realtek fixed the issue in the HD Audio driver package ver.8857 or newer, while driver versions earlier than 8855 that were built using the old version of the Microsoft development tool (VS2005) are still vulnerable to attacks.
If exploited, the vulnerability tracked as
CVE-2019-19705 allows attackers to load and execute malicious payloads within the context of a Realtek-Semiconductor signed process on machines running an unpatched version of the HD Audio driver.
Severe DLL hijacking flawThe Realtek HD Audio Driver Package bug discovered by SafeBreach Labs security researcher Peleg Hadar requires potential attackers to have Administrator privileges prior to successfully exploiting the issue.
Even though this flaw's threat level is not immediately apparent seeing that it requires elevated user permissions and local access to be abused, such security issues are regularly rated with medium and high severity CVSS 3.x base scores.
Attackers abuse
DLL search-order hijacking bugs such as this as part of
binary planting attacks designed to help them further compromise the device and to gain persistence.
Upon successful exploitation, it can be used "for different purposes such as execution and evasion" and "to load and execute malicious payloads in a persistent way,"
Hadar says.
Arbitrary unsigned DLL loading from the current working directoryHadar says that CVE-2019-19705 is caused by the signed HD Audio Background (RAVBg64.exe) process attempting to load a DLL from its current working directory (CWD) instead of the DLL's actual location and its failure to validate if the DLLs is signed with a digital certificate.
He found that the HD Audio Background process that runs as NT AUTHORITY\SYSTEM tries to import the RAVBg64ENU.dll and the RAVBg64LOC.dll from its CWD, the C:\Program Files\Realtek\Audio\HDA\ directory, although they are not located there.
To exploit his finding, the researchers compiled and implanted an arbitrary DLL in the C:\Program Files\Realtek\Audio\HDA\ folder as part of a proof-of-concept demonstration, and restarted the HD Audio Background process.
This allowed him to load the arbitrary DLL and execute a code payload within the RAVBg64.exe process signed by Realtek Semiconductor and running as NT AUTHORITY\SYSTEM.
Proof of concept (SafeBreach Labs) - click to enlarge"With Realtek High Definition Audio version 8855, the local user is able to gain privileges via a crafted DLL in the same folder as the running executable file," according to Realtek's
advisory.
"The root cause is that Microsoft Visual Studio 2005 MFC is used in the named driver package (version 1.0.0.8855), which automatically loads a resource DLL.
The VS2005 MFC uses a low-level function LdrLoadLibrary that also loads a code section, and thus there is a potential risk that unexpected code may be loaded."
"An attacker can implant malware which will be executed on behalf of Realtek which can lead to bypassing AVs, and allows the attacker to steal all of the victims’ information," SafeBreach Labs security researcher Peleg Hadar told BleepingComputer.
When asked what platforms are affected by the vulnerable Realtek HD Audio Driver versions Peleg said that SafeBreach Labs "checked Windows 10, but I believe other versions are vulnerable as it’s an inherited problem."
Other DLL hijacking flaws discovered by SafeBreach LabsThe Realtek HD Audio Driver Package flaw is not the first DLL preloading bug spotted and reported to a vendor by SafeBreach Labs' security researcher Peleg Hadar.
Since August 2019, he also unearthed other similar issues affecting several other software products including but not limited to Symantec Endpoint Protection, Trend Micro's Password Manager, Check Point Software's Endpoint Security Initial Client, the free version of Bitdefender Antivirus, Avira's Antivirus 2019 software, Avast Software's AVG Antivirus and Avast Antivirus, and several McAfee Antivirus software solutions.
Each of the LPE bugs he found could make it possible for hackers to exploit systems running unpatched versions of the vulnerable software to drop and execute malicious payloads in a persistent way, as well as to evade detection during later stages of an attack.
