Kestrel GX is a fast and easy to use digital photo manager and photo editor software. With Kestrel GX managing and editing photos is a breeze, as it enables you to import photos from your camera, edit them and catalog them with incredible ease. Kestrel GX lets you attach searchable keywords and description to each photo file so it can be searched easily.
Kestrel GX can also catalog photos that are on external media such as: DVD, flash drive or external hard disk and you can search through the photo collection even when your external media is not connected. Kestrel GX’s powerful cataloging and search functions are supplemented with a range of supporting functionalities. You will be able to: convert your images to several other formats, create photo books, build your own printing and watermark templates, view slideshows, perform several batch operations like resize, rotate, flip, rename and much more.
And if you are new to photo editing, Kestrel GX’s built-in photo editor will help you edit your photos like a pro in just 10 simple steps! You can also enhance your images with a wide range of special effects like filters, frames, vignettes, polaroid effect, tilt-shift effect and more.
Please note that Cerieus, the developer of Kestrel GX, uses the OpenCandy network to provide recommendations of other third party software during installation. Make sure to opt-out if you don’t need a software being offered. Note that 5 best improvement ideas will be rewarded with tech support and lifetime license for Kestrel GX. Use Idea Informer widget to submit your feedback and do not forget to fill in your name and e-mail – otherwise the Developer will not be able to contact you in case you are the one to win! Download Kestrel GX Unzip the package you've downloaded, and carefully read the instructions which you can find in the readme.txt file. This readme.txt file is included with all our downloads. Follow the instructions carefully to install and activate the software.
VIDEO
