I like finding risk-free ways to try out Linux distros because I can show them to folks who are curious about Linux but not yet ready to throw the Windows discs into the trash can. One way to try Linux while keeping your Windows installation intact is to use Portable Ubuntu.
Portable Ubuntu is a great idea. It’s a stand-alone 440MB package that you download to your PC (Windows only, no Mac flavor) and extract onto your PC or portable flash drive so you can take the OS with you when you’re on the move (you need 2GB of space for the extracted files). To get the ball rolling you then fire up Portable Ubuntu via the Command Prompt (under Vista and Windows 7 this needs to have admin privileges). However, if you’re expecting to see a full Linux desktop you’re out of luck. What you get is a nifty toolbar that looks and feels like Ubuntu’s own launcher.
Portable Ubuntu is really nice and well thought out. Not only are all changes you make to the Linux distro saved automatically, but you can add and remove Linux programs to suit your needs.
Note: To make changes to the OS you need the root password, which in this case has been set to 123456 (you might want to change that).Portable Ubuntu is a great bit of kit for those wanting a portable OS solution or wanting to try out Ubuntu. For Linux newbies it’s a good way to take Ubuntu for a test drive without having to commit an entire PC to the project.
