Author Topic: Build 7600 RTM Leaked x64 | PLEASE Place All Posts HERE ++HOT++  (Read 11501 times)
Offline phat vapor
Re: Build 7600 RTM Leaked PLEASE Place All Posts HERE ++HOT++
« Reply #50 on: July 13, 2009, 01:21:12 PM »
ur need to use a activator again
Offline ataffonso
  • Newbie
« Reply #51 on: July 13, 2009, 04:43:38 PM »
Hi, i can use older two archives token.dat and pkeyconfig.xrm-ms from 7264 activation too?
thank you so much
Offline phat vapor
« Reply #52 on: July 13, 2009, 05:21:47 PM »
i can confirm 7600 is not a fake the setup.exe read 7600
Online riso
« Reply #53 on: July 13, 2009, 05:42:41 PM »
It's real but for now x64 only.. x86 is coming up soon.
Grab your .Torrent here:
http://torrents.thepiratebay.org/5000382/Windows_7_RTM_(build_7600)_64-bit_English.5000382.TPB.torrent
7600.16384.090710-1945_x64fre_client_en-us_Retail_Ultimate-GRMCULXFRER_EN_DVD.iso
SHA1: 0x31849B315290EFABFD81F967ED3C553D82925E4C
DEAD LINK
« Last Edit: July 14, 2009, 07:48:37 PM by javajolt »
Offline Jake
« Reply #54 on: July 13, 2009, 05:54:12 PM »
Due to the debate over whether this is the real final RTM (the minor build number is still subject to change), I've got some good news.  Select partners will be receiving the final RTM on July 24th, and hopefully a legit way of activation.  Pray for a leak.
There's no place like 127.0.0.1
Offline phat vapor
« Reply #55 on: July 13, 2009, 06:30:24 PM »
i,m running 7600 x64 now there are no water marks so this could well be the rtm or very close to the rtm
Offline pb3176
  • Newbie
« Reply #56 on: July 13, 2009, 07:04:49 PM »
does the installer let you select what version you want installed?
Offline Jake
« Reply #57 on: July 13, 2009, 07:16:30 PM »
It's extremely close, but there's always the chance that they change something at the last minute, and leave the major build number as-is.  With Vista they changed the minor build string 3 times while still keeping it as the same major build number.
Offline Snuffy
« Reply #58 on: July 13, 2009, 08:38:12 PM »
It is more than likely close to RTM (Fini) but it is not.
1. you have a EI (verifies not final)=ultimate install only
[EditionID]
Ultimate
[Channel]
Retail
[VL]
0
2. you have a CVersion (verifies not final)=7233
[HostBuild]
MinClient=7233.0
MinServer=7100.0
The only STUPID Question is the one you never asked.
Offline jarucho
  • Newbie
« Reply #59 on: July 13, 2009, 09:06:00 PM »
Rumours are getting stronger that this is not the actual final RTM. There are some missing things that there were supposed to be there like the automatic get started windows, or the "welcome to windows" message. However I have something clear in my mind, minor changes between this and the final RTM. I am not going to install this, although I already have it, and I will wait until 24th July.
Offline Jake
« Reply #60 on: July 13, 2009, 10:13:53 PM »
If anything the core product is finished, next comes the cleaning up and polishing for the OBE stuff.  Supposedly the official announcement is being made tomorrow at the WPC.
Offline macmind
  • Newbie
« Reply #61 on: July 14, 2009, 12:35:27 AM »
Sorry for the stupid question but could you explain the "activator"?
Thanks!!!
Offline m0nk3y
  • Newbie
« Reply #62 on: July 14, 2009, 12:42:55 AM »
Does anyone have a good download link for this build? Or am I trying to find that too early still?
Offline Patrice14
  • Newbie
« Reply #63 on: July 14, 2009, 01:15:33 AM »
ima just wait on x86 patiently
Offline littlemax9
“People liked NASCAR because the constant crashes made it exciting, and this gave me an idea...” - Bill Gates on Microsoft Windows
Offline carlsberg112
  • Newbie
« Reply #65 on: July 14, 2009, 04:22:25 PM »
waiting for the 32bits version , hope that comes soon  ::)
Offline FDamiani
  • Newbie
« Reply #66 on: July 15, 2009, 12:49:15 AM »
I believe this is not the final RTM, the reason is that once you install the activator, the water mark appears and the most conclusive thing is that RTM's haven't expiration date as this does.
Offline madindehead
  • Jr. Member
« Reply #67 on: July 15, 2009, 10:56:42 AM »
Anyone done an upgrade from a previous version using this?
Online riso
X86 32 bit Build 7600 RTM Leaked ++HOT++
« Reply #68 on: July 15, 2009, 10:56:42 AM »
HOT HOT HOT
Just LEAKED Build 7600 X86 32 bit  Cn with Languagepack look here for all info
http://www.windows7newsinfo.com/smf/index.php/topic,1878.msg4228.html#msg4228
Enjoy
riso
Tech support
Offline madindehead
  • Jr. Member
« Reply #69 on: July 15, 2009, 01:18:34 PM »
Does anyone know how I could upgrade from RC build 7127 to this new version please? I don't really want to reinstall unless this build is amazing!
Offline FDamiani
  • Newbie
« Reply #70 on: July 15, 2009, 04:30:33 PM »
Hi, I've made an upgrade from version 7264 straight and previously from RC1 7100 (in this case I'd to do the following)
       1. Download the ISO as you did previously and burn the ISO to a DVD.
       2. Copy the whole image to a storage location you wish to run the upgrade from (a bootable flash drive or a directory on any partition on the machine running the pre-release build).
       3. Browse to the sources directory.
       4. Open the file cversion.ini in a text editor like Notepad.
       5. Modify the MinClient build number to a value lower than the down-level build. (For example, change 7100 to 7000)
       6. Save the file in place with the same name.
  # Run setup like you would normally from this modified copy of the image and the version check will be bypassed ok!
Offline jychan28
  • Newbie
Re: Build 7600 RTM Leaked x64 | PLEASE Place All Posts HERE ++HOT++
« Reply #71 on: July 16, 2009, 09:50:30 AM »
I've just installed the 7600 16384 x64 and it is running fine (not enough time see any bugs yet).
It is interesting that the water mark was not there.
HOWEVER, THIS VERSION CANNOT BE ACTIVATED WITH RC PRODUCT CODE like the last version.
After using the older version "two files" trick, it was activated.  THE WATER MARK COMES BACK!!!
                      Windows 7
Evaluation copy. Build 7600
I hope someone is listening.  There is more to the two files which control the software security protections.
Offline phat vapor
« Reply #72 on: July 16, 2009, 02:07:04 PM »
yep i used the crack and it works fine for me
Offline madindehead
  • Jr. Member
« Reply #73 on: July 16, 2009, 04:40:49 PM »
You running x64 and rebooted it loads? =)
Offline phat vapor
« Reply #74 on: July 16, 2009, 06:57:06 PM »
yes i reboot and all loads fine
Offline Jake
« Reply #75 on: July 16, 2009, 08:30:51 PM »
Maybe it's just a fluke but my copy of 7600 never asked for the key?
I'm not sure if it has the genuine advantage mark, but I'll check later when I reboot into that partition.
Offline Bawls
  • Newbie
« Reply #76 on: July 17, 2009, 12:01:44 AM »
Another 7600 x64 activated user here.  Replaced the token, etc files and used RC key to activate worked just fine.  Make sure to open where you enter your cd key while disabling and re enabling the software security service.  I didn't on first install and couldn't get back to the cdkey entry screen. Just said it was unavailable.
Offline jychan28
  • Newbie
« Reply #77 on: July 18, 2009, 03:07:25 AM »
No water mark after activation?
Offline madindehead
  • Jr. Member
« Reply #78 on: July 18, 2009, 07:10:20 PM »
I have a watermark, but it's all activated properly using a RC key. Looking like a great build =D
I clean installed from using RC build 7127 for ages. Even better than that, and that was an AWESOME build =D
Build 7600 RTM Icon
« Reply #79 on: July 19, 2009, 05:59:21 AM »
6.1.7600.16384.win7_rtm.090710-1945
