In this tutorial, we'll learn how to set the Command Bar auto-hidden in Explorer window. In this way, it'll only appear when you hover your mouse cursor over it as shown in following screenshot:
Auto-Hidden Command Bar aka Folder Band:
To make the Command Bar auto-hidden, you'll have to edit the "
Shellstyle.dll" file which is present in Theme directory.
For example, if you are using default Window Aero theme, you'll get the "Shellstyle.dll" file in following directory:
%windir%\Resources\Themes\Aero\Shell\NormalColor
NOTE: If you are using
Windows Classic theme, you'll need to edit "
Shellstyle.dll" file present in "
Windows\System32" folder.
You just need to follow these simple steps to make Command Bar auto-hidden:
1. Open "
Resource Hacker.
2. Now go to "
UIFILE -> 1 -> 1033".
3. Press <
Ctrl>+
F or click on "
View ->
Find Text..." option and type following in "
Find what" textbox:
<style resid="FolderBandStyle">
4. It'll go to following line of code:
<Element
background="argb(0, 0, 0, 0)"
5. Now add following code after
<style resid="FolderBandStyle"> line:
<if mousefocused="false" mousewithin="false"><Element padding="rect(0rp,0rp,0rp,-28rp)"/></if>
So that it'll look as following:
<Element
PS: To permanently disable or hide Command Bar, add following code after
6. Now click on "
Compile Script" button and save the file.
7. Log off or restart to see the changes OR re-apply the theme.
PS: This method will work for all 3rd party themes as well. Simply modify the "Shellstyle.dll" file present in custom theme folder.
NOTE: If you want a ready-made modified "shellstyle.dll" file, you can download it using following
link and replace the default file in your system with it. You might need to
take ownership of default "shellstyle.dll" file before replacing it.
Download Link
