This is for educational and experimental purposes only and is not meant to circumvent any activation processes.
Windows 7 Loader v2.0.2 By Daz
AboutThis is the loader application that's used by millions of people worldwide, well known for passing Microsoft's WAT (Windows Activation Technologies) and is arguably the safest Windows activation exploit ever created. The application itself injects a SLIC (System Licensed Internal Code) into your system before Windows boots; this is what fools Windows into thinking it's genuine.
Features Can be run as a standalone application
Works well with all system languages
Custom OEM information can be installed
Argument support for silent installs
Can be used for pre-activation
Application integrity checking
Custom error handling
Support for hidden partitions and complex setups
Can work alongside Linux's GRUB or any other boot manager
Works with TrueCrypt and many other types of hard drive encryption applications
Add your own certificates and serials externally
Offers certificate and serial installation only for users with an existing SLIC 2.1
Automated system profiling (The application matches everything up for you)
The rundownCompatible with Windows 7 SP1 and all system updates ✔ check
Will run on x86 and x64 systems ✔ check
No core system files get modified ✔ check
No extra processes are run so you have nothing eating at your RAM ✔ check
All key parts of the exploit are encrypted with a custom encryption ✔ check
The exploit runs before Windows so it's harder for Microsoft to prevent ✔ check
The exploit patches all necessary tables making activation look authentic ✔ check
The application will select the best profile for your system during installation ✔ check
Each and every user has a unique version of the exploit installed on his/her system ✔ check
Supported operating systems Windows 7 Ultimate ✔
Windows 7 Ultimate E ✔
Windows 7 Professional ✔
Windows 7 Professional E ✔
Windows 7 Home Premium ✔
Windows 7 Home Premium E ✔
Windows 7 Home Basic ✔
Windows 7 Starter ✔
Windows 7 Starter E ✔
Windows Vista Ultimate ✔
Windows Vista Business ✔
Windows Vista Business N ✔
Windows Vista Home Premium ✔
Windows Vista Home Basic ✔
Windows Vista Home Basic N ✔
Windows Vista Starter ✔
Windows Server 2008 R2: Enterprise ✔
Windows Server 2008 R2: Standard ✔
Windows Server 2008 R2: Foundation ✔
Windows Server 2008: Enterprise ✔
Windows Server 2008: Standard ✔
Windows Server 2008: Foundation ✔
Windows Small Business Server 2008 ✔Note: You must be running build 7600 or greater for Windows 7 and Windows Server 2008 R2.
Note: I don't recommend using any of the Windows 7 E editions.
Note: Windows 7 N editions will only be supported when OEM SLP serials leak.
Application integrity checking?
Hover your mouse over the green, amber or red icon to see detailed application information.
Note: Even if the icon is green someone might have found a way around the protection system so it's worth checking that the applications path is always the same as the location from which you launched the application. You should also check that the MD5 matches the MD5 found online.
Virus scanner resultsAll virus scanner detection's are a false-positive. Simply turn off your anti-virus while installing the loader.
Version 2.0.2 (05/23/2011)
* Added a new GRLDR version
* Added TAROX Ultimate, Professional, Home Premium and Starter serials
* Fixed a bug that caused the wrong certificate to be dumped on some machines
* Added a prompt to ignore the existing SLIC on a system if the SLIC is invalid
* Other minor tweaks and fixes
Version 2.0.1 (05/09/2011)
* Added TAROX and Vestel SLIC's
* Added Positivo and Kraftway Home Basic serials
* Enhanced the installation of GRLDR
* Enhanced the dump option so that it will now dump the certificate and serial as well as the SLIC
Version 2.0.0 (04/05/2011)
* Fixed a bug that could cause the application to crash
* Fixed unicode character input for OEM information editing
Version 1.9.9 (04/04/2011)
* Fixed sandbox bug
Version 1.9.8 (04/03/2011):
* Added OEM branding options
* Added AT Computers, Genuine & Zoostorm SLIC's
* Added Genuine Home Premium serial & Zoostorm Starter serial
* Enhanced error handling
* Enhanced enviroment detection
Version 1.9.7 (02/18/2011):
* Added a new GRLDR version (This should fix many problems)
* Added Viewsonic Starter serial
Version 1.9.6 changes (02/03/2011):
* Added Aquarius, Hannspree, Hyrican, Lanix, Semp Toshiba, Twinhead & Synnex SLIC's
* Added Exper, Fujitsu and Hannspree Starter serials
* Added Dealin, Founder and Fujitsu Home Basic serials
* Added Gigabyte and Shuttle Home Premium serials
* Added Dealin and Mercer Professional serials
* Added Fujitsu Ultimate serial
* Added HP serials for UltimateE, ProfessionalE, HomePremiumE & StarterE
Version 1.9.5 changes (11/23/2010):
* Added a new GRLDR version which fixes a bug that prevented activation on systems with an XSDT
Version 1.9.4 changes (11/21/2010):
* Added a new GRLDR version (Improves the ignore existing SLIC function)
* Disabled table sorting by default for compatibility reasons
* Added an option to disable type 3 memory as well as an option to reverse the SLIC search direction
* Displays motherboard version to help with debugging
* Added ECS, Dealin, Higrade and KSystems SLIC's
* Added HCL, KSystems and MSI Home Basic serials
* Added MSI Professional serial
* Added Dealin Home Premium serial
HOW TO INSTALL1.Download file
2.Right click on it "Run As Administrator"
3.Click Install
4.Click Yes if some message pop up.
5.Wait for reboot.
6.Your Windows 7 is genuine!
SYSTEM WON'T BOOT?1.Boot up the PC from your Windows installation disk
2.Select the "Repair your computer" option
3.Select "Command Prompt"
4.Input "bootsect.exe /nt60 SYS /force" (Without quotes)
5.Restart the PC
Download:http://www.fileserve.com/file/vVEqBZw
or
http://www.mediafire.com/?tbtek7y2dk16c2z
or
http://www.megaupload.com/?d=U0QS6H65
IF YOU HAVE PROBLEMS READ FAQhttp://www.fileserve.com/file/8zHJnwK
UPDATE :Version 2.0.3 (27/05/2011)* Added a new GRLDR version
* Removed the prompt to ignore invalid SLIC's and have made the setting apply for Samsung systems only
download:
http://www.filesonic.com/file/1229931104
