Author Topic: Dell launches 2018 XPS 13 laptop (this time it’s even thinner)  (Read 2481 times)
Dell helped kick off the thin-bezel laptop trend in 2015 when the company launched a Dell XPS 13 laptop with a 13.3-inch display stuffed into a laptop the size of a typical 11.6-inch model.
Since then, Dell has updated the XPS 13 several times by upgrading the processor and other internal components. But the design hasn’t changed much… until now.
Dell is kicking off 2018 by introducing an updated XPS 13 with a thinner body, slimmer bezels, a new set of ports, and two color options: black or white.
The new Dell XPS 13 with 8th-gen Intel Core processor options will be available this month for $950 and up. That’s the starting price for a new XPS 13 Developer Edition with Ubuntu Linux. Windows models will sell for $1000 and up.
Last year’s models will also continue to be available through this summer, with prices starting at $800 for a model with a 7th-gen Core i3 chip (which makes sense, since there is no 8th-gen Core i3 processor yet).
Like its predecessor, the new Dell XPS 13 weighs about 2.7 pounds. What’s new is that the 2018 model measures just 11.6mm (0.46 inches) thick at the thickest point.
Dell has also added a Windows Hello-compatible IR camera that allows you to unlock the computer using facial recognition, and the camera has been moved… from the left side of the laptop to the center. Unfortunately, it’s still below the screen instead of above the display, which means you may end up photographing your knuckles or getting some unflattering shots of your chest and/or chin when taking selfies or making video calls.
I’m told Dell knows the camera position is less than ideal… but that the company determined that most people don’t actually use the webcam very much, relying on smartphones for selfies and video calls anyway. So in order to have as slim a top bezel as possible, the company continues to put the camera below the screen. Interestingly, Dell’s new Latitude laptops have slightly thicker top bezels and cameras above the screen. Apparently, Dell figures business customers to use their webcams.
Speaking of super-slim bezels, the new XPS 13 top and size bezels are thinner than ever, at about 4mm.
Dell has also changed the port layout: the 2018 XPS 13 has two Thunderbolt 3/USB Type-C ports on the left side, one USB 3.1 Type-C port on the right side, and headset jack and microSD card port.
There are no full-sized USB ports, no HDMI ports, and no dedicated power jacks. The laptop comes with a USB Type-C power adapter and you can plug it into any of the USB ports to charge the notebook.
You’ll need an adapter or docking station if you want to plug in an Ethernet or video cable though.
Or you can buy a 2017 model if you’d prefer a laptop with a few full-sized USB ports.
Dell now offers a new white color option, but it’s not just the color that’s new. The black and silver XPS 13 has a carbon fiber composite palm rest with a soft touch finish, but the white version has a glass fiber palm rest with a harder feel to it. At first, the white model felt a little plastic-like, but the more time I spent with it, the more I got to like the feel of the textured glass fiber finish.
The white version also has a blue backlight for the keyboards rather than white, since Dell determined that white-on-white looked funny.
Here’s a run-down of the specs and options that will be available for the 2018 Dell XPS 13 at launch:
Display
   • 13.3 inch 1920 x 1080 pixel (72% color gamut)
   • 13.3 inch, 1920 x 1080 pixel touchscreen (72% color gamut)
   • 13.3 inch, 3840 x 2160 pixel touchscreen (100% sRGB)
Processor
   • Intel Core i5-8250U
   • Intel Core i7-8550U
Memory
   • 4GB 1866MHz dual-channel
   • 8GB 1866MHz dual-channel
   • 16GB 2133 MHz dual-channel
Storage
   • 128GB SATA SSD
   • 256GB PCIe SSD
   • 512GB PCIe SSD
   • 1TB PCIe SSD
Operating System
   • Windows 10 Home 64-bit
   • Windows 10 Pro 64-bit
   • Ubuntu 16.04 (Fingerprint reader not supported)
Other features include stereo speakers, 802.11ac WiFi, Bluetooth 4.1, and a 52 Whr battery. The Dell XPS 13 measures 11.9″ x 7.8″ x 0.3″ at the thinnest point ant 0.46″ at the thickest.
Dell says the laptop supports more than 19 hours of battery life according to the MobileMark battery test (or 11 hours with a 4K display), but you should probably knock at least a few hours off that to get an idea of what to expect in real-world settings.
The company also updated the cooling system, using dual fans and dual heat pipes in order to keep Intel’s 15-watt processor cool even when it’s running at up to 27 watts.
Dell will also ship the computer with software that allows users to choose from different performance profiles depending on whether they want to prioritize performance or battery life… with the lower performance mode also allowing the CPU to run at a cooler temperature and keep the fan from making as much noise. The company is still fine-tuning that software though, so there won’t be much difference between the performance modes at launch. Dell plans to offer a BIOS update in the future that will give users more control over the computer’s CPU and cooling performance.
