Author Topic: Red Hat warns of backdoor in XZ tools used by most Linux distros  (Read 948 times)
Today, Red Hat warned users to immediately stop using systems running Fedora development and experimental versions because of a backdoor found in the latest XZ Utils data compression tools and libraries.
"PLEASE IMMEDIATELY STOP USAGE OF ANY FEDORA 41 OR FEDORA RAWHIDE INSTANCES for work or personal activity," Red Hat warned on Friday.
"No versions of Red Hat Enterprise Linux (RHEL) are affected. We have reports and evidence of the injections successfully building in xz 5.6.x versions built for Debian unstable (Sid). Other distributions may also be affected."
Debian's security team also issued an advisory warning users about the issue. The advisory says that no stable Debian versions are using the compromised packages and that XZ has been reverted to the upstream 5.4.5 code on affected Debian testing, unstable, and experimental distributions.
Linux admins can check what version of XZ is installed by running the 'xz -V' command in a terminal. If you are using versions 5.60 or 5.61, you are advised to immediately downgrade to older versions that do not contain the malicious code.
Microsoft software engineer Andres Freund discovered the security issue while investigating slow SSH logins on a Linux box running Debian Sid (the rolling development version of the Debian distro).
However, he has not found the exact purpose of the malicious code added to XZ versions 5.6.0 and 5.6.1.
"I have not yet analyzed precisely what is being checked for in the injected code, to allow unauthorized access. Since this is running in a pre-authentication context, it seems likely to allow some form of access or other form of remote code execution," Freund said
"Initially starting sshd outside of systemd did not show the slowdown, despite the backdoor briefly getting invoked. This appears to be part of some countermeasures to make analysis harder."
Red Hat reverts to XZ 5.4.x in Fedora Beta
Red Hat is now tracking this supply chain security issue as CVE-2024-3094, assigned it a 10/10 critical severity score, and reverted to 5.4.x versions of XZ in Fedora 40 beta.
The malicious code is obfuscated and can only be found in the complete download package, not in the Git distribution, which lacks the M4 macro, which triggers the backdoor build process.
If the malicious macro is present, the second-stage artifacts found in the Git repository are injected during the build time.
"The resulting malicious build interferes with authentication in sshd via systemd. SSH is a commonly used protocol for connecting remotely to systems, and sshd is the service that allows access," Red Hat said.
"Under the right circumstances this interference could potentially enable a malicious actor to break sshd authentication and gain unauthorized access to the entire system remotely."
CISA also published an advisory today warning developers and users to downgrade to an uncompromised XZ version (i.e., 5.4.6 Stable) and to hunt for any malicious or suspicious activity on their systems.
