Author Topic: The First USB 3.0 Flash Drive and Hard Drives  (Read 2498 times)
Offline riso
« on: November 05, 2009, 08:43:15 AM »
Super Talent's first USB 3.0 flash drive, is huge—about the same size as Corsair's Voyager, in 32GB, 64GB and 128GB sizes. It'll push those gigs of Zatoichi rips at 4.8Gbps, or about 10x faster than USB 2.0. Of course, you need a computer running one of these motherboards or cards, since Intel's dragging ass on a standard it helped developed. And you might as well pick up one of these hard drives too:
Buffalo is set to cross the USB 3.0 finish line first with their HD-HU3 hard drive. They also plan on offering NEC's IFC-PCIE2U3 2-port PCI Expressx1 host controller with the drive so you can, you know, use it.
The drives will be available this month—although it appears to be a Japan-only release for the moment. The drives will run around $250 and $284 for 1TB and 1.5TB models respectively (a 2TB model is also in the works.), and the controller will run an additional $60. It's probably a bit early to jump on 3.0, but chances are we won't have to wait long before the technology goes mainstream.
« Last Edit: November 05, 2009, 08:44:53 AM by riso »
