Author Topic: Buffalo 3TB media hub  (Read 1790 times)
Offline riso
« on: October 14, 2011, 04:01:58 PM »
Buffalo has unveiled a new external hard drive that allows users to adjust the visible storage capacity on the fly. Supposedly the first of its kind, the HD-ALC3.0TU2/V is designed to work with "smart" televisions that lack support for today's high-capacity 3TB media hubs. Most households have more than one viewing device and some might support large drives, so buying a less capacious solution to accommodate the weakest link might not be appealing.
As a workaround, Buffalo's new 3TB external device offers a switch that lets you reduce the visible space to 2TB or 1TB as required. There's nothing magical about the setup as it requires you to create separate partitions. The knob simply lets you tick between them. We can only assume this is because some TVs can't see multiple drive partitions, so Buffalo's solution would let you jump between a 2TB video partition and a 1TB music partition, for example.
