Author Topic: iOS 11 release date is today. Here's how to get your iPhone or iPad ready  (Read 3044 times)
iOS 11 is scheduled to be released tomorrow (although here's a way you can get your hands on it today if you want), and if you're thinking about upgrading to iOS 11 the moment it's released, there are some steps that you should take so you don't end up in a world of hurt.
HOW TO GET IOS 11
The recommended way is to tap Settings > General > Software Update and carry out the refresh from there.
Alternatively, you can connect the iPhone or iPad to a PC running iTunes and do the upgrade from there.
WHAT DEVICES CAN RUN IOS 11?
iOS 11 is supported on the following devices:
• iPad Air
• iPad Air 2
• iPad Pro
• iPad mini 2
• iPad mini 3
• iPad mini 4
• iPod touch 6th
• iPhone 5s
• iPhone SE
• iPhone 6/6 Plus
• iPhone 6s/6s Plus
• iPhone 7/7 Plus
This means that not all devices that run iOS 10 can run the iOS 11. Specifically, the following are not supported:
• iPhone 5
• iPhone 5c
• iPad 4
This means that the oldest Apple devices that can support iOS 11 will be the iPhone 5s and iPad Air.
REMEMBER: THINGS CAN GO WRONG!
Before you go hog-wild, throw caution to the wind and start upgrading, be aware that there are risks. Things can go wrong, stuff may be broken, and you may lose data. Plenty of iOS launches have been marred by bugs and problems, so with that in mind, it's a good idea to have an up-to-date backup, because making a fuss isn't going to bring back your lost photos or documents.
You can either create a local backup using iTunes, or backup to iCloud by going to Settings > iCloud > Backup, and then turn on iCloud Backup.
Keep in mind that unless you're willing to jump through hoops and do things that Apple frowns upon, going to iOS 11 is a one-way trip, so you might want to let other people to go ahead of you just in case there are gotchas
SPRING CLEAN YOUR IPHONE OR IPAD
Chances are that your iPhone or iPad has accumulated a lot of detritus over the months and years, so what better time to get rid of it than now.
While iOS 11 doesn't need as much free space to install as some of the earlier releases of iOS, getting rid of apps that you no longer use -- or perhaps have never used -- makes good sense.
KNOW YOUR PASSWORDS
Following the upgrade, you'll need to enter your iCloud password in order to be able to reconnect to all your data and photos. If you don't have this close to hand -- remember, having it on the device you're upgrading isn't all that convenient -- then this might be a good time to do that.
Also, if your iTunes backup is encrypted, then remember you'll need that password if something goes wrong!
PREPARE YOURSELF FOR THE "APOCALYPSE"
The end is nigh for all 32-bit iOS apps, so if you're still relying on older apps, it's time to find alternatives.
For some time now, Apple has been warning iPhone and iPad users that legacy 32-bit apps may slow down their devices, but with the recent release of iOS 10.3, Apple has escalated things by making it clear that the end is nigh.
You can check installed apps for compatibility using the built-in checker tool (you need to be running iOS 10.3 or later for this to work).
You can find that by clicking: Settings > General > About > Applications.
From there, you'll get a list of all the 32-bit apps on your iPhone or iPad that won't run on iOS 11. If you're lucky, you won't have any apps listed, or the apps that are listed will be old stuff that you forgot you had installed and no longer use.
However, if an app that you are relying on is listed, then you need to get ready for its demise.
IS IT BETTER TO UPGRADE OR WIPE THE DEVICE AND START FROM SCRATCH?
It's a lot less hassle to just upgrade a device because you get to keep all your apps and settings.
However, devices that I have wiped and reloaded a new iOS onto, and then installed and re-setup all my apps and such, feel faster and seem to suffer from fewer problems (such as Bluetooth and Wi-Fi issues). However, wiping and reloading the apps and data is a pretty big hassle, and it's probably more work than most want to undertake.
SHOULD I WAIT A WHILE BEFORE DOING THE UPGRADE?
There will likely be an update or two to iOS 11 coming down the pipes over the coming weeks, so you might want to wait for the dust to settle and for any last-minute bugs to be squashed before making the leap, especially if you rely on your device.
Also, if you use your device in a BYOD setting, make sure you get the OK from the IT department before upgrading, in case you're unable to access the network or data you need.
« Last Edit: September 19, 2017, 10:26:10 PM by javajolt »
