Author Topic: Razer announces a new speaker line for PCs  (Read 1945 times)
« on: January 16, 2018, 09:51:20 PM »
At CES 2018 last week, Razer announced a new speaker line for PCs, the Razer Nommo and Nommo Pro. The Nommo Pro is a no- compromise, 2.1 THX Certified speaker with Dolby Virtual Speaker tech whereas the Nommo is an everyday 2.0 speaker.
The Dolby Virtual Speaker technology in the Razer Nommo Pro adds will offer simulated 5.1 surround sound. The Dupont Kevlar coated driver in this speaker will project solid mids, while independent silk-woven tweeters per satellite will produce smooth highs and the cylindrical downward firing subwoofer promotes airflow in deep tones. It features a USB, Optical, Bluetooth and 3.5-millimeter jack. It also allows users to control volume using a control pod. Razer will allow users to customize the EQ settings and bass levels using Razer Synapse 3 and “Nommo Pro” mobile app. The Razer Nommo Pro also comes with Razer Chroma allowing users to select from a palette of 16.8 million color choices.
The Razer Nommo is a regular 2.0 speaker that comes with Custom Woven Glass Fiber 3 Inch drivers for power and clarity and elongated rear-firing bass ports. It also features bass control with Automatic Gain Control to help maintain the integrity of bass. The Razer Nommo Chroma is a Chroma variation of this speaker that comes with USB connectivity and an inbuilt DAC.
Razer Nommo and Nommo Chroma is now available in the US and it will be available worldwide later this month.
