Author Topic: 15 Amazing Shortcuts You Aren't Using  (Read 2313 times)
« on: April 21, 2019, 08:27:48 PM »
If you wanna be a power user, you shouldn't deny the usefulness of hotkeys. They improve your everyday work and give an absolute boost in your productivity. These hotkey combinations will certainly come in handy for every Windows and OS X user!
SUMMARY:
- Press the Windows key   Ctrl   D or Control   Up if you use a Mac. It’ll switch to a new fresh desktop.
-  Push the Windows key   Ctrl or the Control key on a Mac. Now you can switch between all the virtual desktops you’ve made by using the left and right arrow keys.
- If you have too many apps open and you need to use another one hidden behind all those windows on your desktop, you can minimize all of them at once by pushing the Windows key   M.
- If you want much faster access to your most used apps, consider keeping them on your taskbar. It’ll speed up your workflow even more if you use the following combination: the Windows key   a number key from 1 to 9.
- Open one app that you need for your work and press the Windows key   left arrow. Then, open another app and click the Windows key   right arrow. Now, two windows are sharing your screen!
- Pressing Ctrl   Alt   Tab will show you all the apps currently running on your PC.
-  To avoid restarting your device and losing all your progress, try using the following combo: Ctrl   Shift   Esc or Command   Option   Escape if you’re working on a Mac.
- Pressing the Windows key   E opens the file manager window on your PC. For Mac users, this is your Finder app.
- The Windows key combined with the   or - key will open the magnifier app, which allows you to zoom in and out wherever you point your cursor.
- Use the Windows key   Print Screen to take a screenshot and immediately save it in the Image folder on your hard drive.
- To open Bluetooth, simultaneously press the Windows key   A. For Mac users, your Notification Center is always a click away in the top right-hand corner.
- If you need more tweaking or access to more advanced parameters of your PC, you can have it all! Use the Windows key   I to do just that.
- To open Cortana on Windows in listening mode, press the Windows key   C. And to summon Siri on Mac OS, hold Command and Space together. “Hey, Siri!”
- If you suddenly need to step away from the computer but you don’t want anyone meddling in your stuff, you can quickly lock your user profile. Simply push the Windows key   L or Shift   Command   Q on a Mac.
http://www.youtube.com/watch?v=VeAK7Bv4F1o]source[/url]
