Author Topic: Microsoft release Insider Preview Build 19033 (20H1) to the Fast and Slow Ring  (Read 1637 times)
Microsoft has continued to wind down the development of Windows 10 20H1, releasing Windows 10 Insider Preview Build 19033 (20H1) to both the Fast and Slow Ring.
Microsoft notes that they will soon start releasing new builds from their development branch (presumably 20H2) to the Fast Ring, which should mean that builds will soon start becoming unstable again. These will herald the return of the watermark on the desktop.
If you prefer to stay on relatively stable builds now may be a good time to switch to the Slow Ring, or if you want to exit the Insider program, indicate this under Windows Insider Settings, which will cause Microsoft to automatically move you to the Slow Ring, and then exit the program when 20H1 is being released.
The new build contains the following fixes and improvements:
General changes, improvements, and fixes for PC
■ The build watermark at the lower right-hand corner of the desktop is no longer present in this build.
■ Eagle-eyed Windows Insiders will notice that as of this build, 20H1 officially shows it is version 2004. Microsoft has chosen to use 2004 as the version to eliminate confusion with any past product names (such as Windows Server 2003).
■ Microsoft fixed an issue that could result in Settings crashing for some users if you navigated to About when in Safe Mode.
■ Microsoft fixed an issue resulting in some paired Bluetooth audio devices unexpectedly displaying with a cellphone icon in Bluetooth Settings.
■ Microsoft fixed an issue where preferred Focus Assist automatic rules settings weren’t persisting upgrade.
■ Microsoft fixed an issue where pressing the WIN + P keyboard shortcut twice in a row could result in ShellExperienceHost crashing.
■ Microsoft fixed an issue that could result in the Start menu crashing on launch if a Windows update was pending restart.
■ Microsoft fixed an issue where if you were using night light and weren’t already signed into a
■ Microsoft Account, and subsequently attached your MSA, it would result in night light no longer working.
■ Microsoft fixed an issue where if you quickly toggled Magnifier on and back off in Settings it would result in Magnifier.exe crashing.
■ At this point, Microsoft is removing the known issue that Settings still isn’t available outside of launching via the URI (ms-settings:) – so far Microsoft have not seen any reports from Insiders in the Slow ring that bypassed the impacted build range. If you are in the Fast ring, were on the impacted build range, and are one of the few still experiencing this issue, you will need to reset your PC. Microsoft appreciates your patience.
■ Microsoft fixed an issue where you wouldn’t be able to type Chinese punctuation with the Pinyin IME after moving focus to and from a password field.
■ Some users may have experienced error 80092004 when attempting to install build 19025.1052. This was isolated to that specific Cumulative Update and should not prevent installing build 19033.
■ Microsoft has fixed an issue resulting in Start Code 38 with certain external USB 3.0 drives.
Known issues
■ BattlEye and Microsoft have found incompatibility issues due to changes in the operating system between some Insider Preview builds and certain versions of BattlEye anti-cheat software. To safeguard Insiders who might have these versions installed on their PC, Microsoft has applied a compatibility hold on these devices from being offered affected builds of Windows Insider Preview.
■ Microsoft is looking into reports of the update process hanging for extended periods of time when attempting to install a new build.
■ Some Insiders are reporting that after successfully installing printer drivers from the Optional Updates section, the same driver is still showing as available for install. Microsoft is looking into the issue.
■ Microsoft is looking into reports of certain external USB 3.0 drives not responding with Start Code 10 after they’re attached.
Windows 10 Insiders can download the build by Checking for Updates in Settings.
