Author Topic: Windows 10 Insider Build 19564 Released With New Calendar App, GPU Settings  (Read 1644 times)
Microsoft has released Windows 10 Insider Preview Build 19564 to Insiders in the Fast ring, which offers a preview of the new Windows 10 Calendar app and an improved Graphics settings page.
If you are a Windows Insider in the Fast ring, you can update to the Insider Preview Build 19564 by going into Settings -> Update & Security -> Windows Update and then checking for new updates.
To see the full release notes and fixes for this Windows 10 insider build, you can read the blog post.
The most notable changes found in this new build released to Windows Insiders in the Fast ring are detailed below.
Graphics Settings Improvements
This build introduces an updated Graphics Settings page (Settings > System > Display > Graphics settings) that offers better control over deciding what GPU an application will use.
With this release, Windows will attempt to associate an app with a particular device based on its graphics and power requirements. If an app isn't listed, you can now search for it and assign it to a particular GPU.
Improved Graphics Settings
New Windows 10 Calendar Preview
With this release, Microsoft is also letting Windows Insiders preview the new Windows 10 Calendar app.
This preview comes with the following new features:
   1. New themes: choose from over 30 different themes!
   2. Improved month view: Month view now includes an agenda pane that lets you see your day’s events at a glance.
   3. Simplified event creation: We’ve made it even easier to add an event to your calendar.
   4. Redesigned account navigation: We’ve collapsed the account navigation pane, leaving more space for your day’s
       events. All of your syncing calendar accounts are now represented as clickable icons on the left.
To use the preview, enable the "Try the preview" toggle switch at the top right of the Calendar Window.
General changes, improvements, and fixes for PC
• We fixed an issue resulting in East Asian IMEs (Simplified Chinese, Traditional Chinese, Korean and the Japanese IME) potentially being missing from the language/keyboard switcher (e.g. opened by Windows key + Space key) after upgrading from 20H1 Build 19041 or lower builds to Windows 10 Insider Preview build (19536 or later). Please note that this fix will stop it from happening, however, if you were already impacted from a previous build, you’ll need to remove and re-add any keyboards that are missing from the keyboard switcher by going to Settings > Time & Language > Language > Preferred languages, in order to get yourself back into a good
• We’ve updated the Japanese IME so that when using the new Microsoft Edge in inPrivate mode, this will also enable private mode in the IME.
• We fixed an issue from the previous flight where if you brought up clipboard history (WIN+V) and dismissed it without pasting anything, input in many places would stop working until you rebooted your PC.
• We fixed a rare crash when opening the Windows Ink Workspace.
• We fixed an issue that could result in the Wheel UI (that you’d see when using a Surface Dial) crashing when no custom commands had been configured.
• We fixed an issue that could result in the login screen password field unexpectedly not rendering.
• WSL Issue 4860: We’ve fixed an issue resulting in some Insiders experiencing this error message when using WSL2: A connection attempt failed on Windows.
We’ve resolved one issue preventing some Insiders from updating to newer builds with error 0xc1900101. We’re continuing to review logs to further investigate additional issues with this error code.
• We fixed an issue with the Windows setup UI (that you would see when using an ISO, or if prompted to fix issues impacting Windows Update, such as low space) where the apostrophe in “you’re” was replaced by junk characters.
• We fixed an issue resulting in certain devices no longer sleeping on idle in recent builds.
• We reduced TLS usage in certain shell components. What does that mean for you? Basically, we made things take a little less memory, which also helps certain apps that are sensitive to TLS usage.
• We fixed an issue resulting in a small set of Insiders seeing their system time unexpectedly jump forward.
• We fixed a crash resulting in some Insiders seeing a green screen with a CRITICAL_PROCESS_DIED error message.
• We fixed an issue that could result in a deadlock (where everything would freeze) when using your PC.
• We fixed a crash some Insiders were hitting in EoaExperiences.exe when using the text input cursor indicator.
• We fixed an issue resulting in not being able to set focus to the search box in the common file dialog when launched from remote desktop connection settings and certain other apps.
• We fixed an issue where File Explorer wasn’t calculating the correct folder size in Properties when the UNC path was longer than MAX_PATH.
• We fixed an issue where the banner at the top of Settings might say an update was in progress, even though Windows Update Settings would say you’re up to date.
• For Insiders that have the Settings header, you may notice the OneDrive icon has been updated with today’s build.
• We fixed an issue resulting in Settings crashing when selecting sync across devices > Get Started under Clipboard.
• We fixed an issue with wallpaper transitions on Build 19536+, which was affecting some third-party wallpaper apps.
Known issues
• BattlEye and Microsoft have found incompatibility issues due to changes in the operating system between some Insider Preview build and certain versions of BattlEye anti-cheat software. To safeguard Insiders who might have these versions installed on their PC, we have applied a compatibility hold on these devices from being offered affected builds of Windows Insider Preview. See this article for details.
• We are aware Narrator and NVDA users that seek the latest release of Microsoft Edge based on Chromium may experience some difficulty when navigating and reading certain web content. Narrator, NVDA and the Edge teams are aware of these issues. Users of legacy Microsoft Edge will not be affected. NVAccess has released an NVDA 2019.3 that resolves the known issue with Edge.
• We’re looking into reports of the update process hanging for extended periods of time when attempting to install a new build.
• We’re investigating reports that some Insiders are unable to update to newer builds with error 0x8007042b.
• The Documents section under Privacy has a broken icon (just a rectangle).
• When you upgrade with certain languages, like Japanese, the “Installing Windows X%” page isn’t rendering the text correctly (only boxes are displayed).
• The cloud recovery option for Reset this PC isn’t working on this build. Please use the local reinstall option when performing Reset this PC.
