Author Topic: Windows 11 System Requirements  (Read 7318 times)
« on: June 25, 2021, 01:38:21 PM »
According to Microsoft, if your computer doesn’t meet the following requirements, your device will not be able to run Windows 11. If that’s the case, you’ll need to buy a new PC to run the new operating system.
• Processor: 1 GHz or faster with 2 or more cores on a compatible 64-bit processor. (Microsoft provides a list of compatible processors on its website).
• RAM: 4 gigabytes or more
• Storage: 64 GB or larger storage device (such as a hard drive or SSD)
• System Firmware: UEFI and Secure Boot capable
• TPM: Trusted Platform Module 2.0 (common on motherboards manufactured after 2016)
• Graphics Card: Compatible with DirectX 12 or later with WDDM 2.0 driver
• Display: An HD display at least 720p (1280×720) resolution larger than 9″ diagonal, 8-bits per color channel
• Internet Connection and Microsoft Accounts: Windows 11 Home edition requires an internet connection and a Microsoft account to set up the device on first use. Switching a device out of Windows 11 S mode also requires an internet connection.
Of all these features, the requirement for TPM 2.0 might be the most unexpected reason your slightly older Windows 10 PC can’t run Windows 11. You can check your system’s TPM version by running tpm.msc in the Run dialog.
Unfortunately, the app does not tell you what system requiements you failed to meet.
« Last Edit: June 25, 2021, 05:13:53 PM by javajolt »
