Author Topic: Panda Cloud AV Gets Creative With Its Detections  (Read 1669 times)
« on: May 10, 2010, 06:04:28 PM »
The latter is a free product, the best of them according to us recently. As I explained in the earlier blog, I like to change antivirus products periodically, generally when the license runs out, in order to gain more face time with more products. I had a system running Microsoft's free Security Essentials and was happy with it, bit of course the license will never expire. I decided to move this system, a Pentium 4 with 64-bit Windows 7 Ultimate, to Panda Cloud Antivirus and to allow the contest for the other system, on which Kaspersky Internet Security is approaching expiration, to the other two products.
Installation of Panda Cloud AV was a trivial exercise. Once it was on I left it to perform its initial scan and went off to do other things. When I came back.I saw that it had flagged c:\windows\syswow64\appsetup.exe as a "dialer." Dialers are malware which make phone calls using your modem for various purposes. I checked the file and noted that it was digitally signed by "Creative Technologies Ltd." and likely was related to the SoundBlaster card in my system. Some quick Googling supported my belief that this file was an actual Creative SoundBlaster executable.
I contacted Panda and they quickly acknowledged that the file was a false positive. They showed me how to clear the detection in my system and they fixed it in their own databases. Like other vendors, they have lists of particular identities to check for in digital signatures so that they can whitelist, for example, the executables that Microsoft ships with Windows. But Creative wasn't on Panda's list.
Such whitelisting is a critical technique not just for avoiding false positives, but for improving performance, at least of full scans. Good whitelisting practices might have saved McAfee a lot of trouble with their own recent false positive fiasco.
I'm sticking with Panda on that system. So far I haven't noticed any impact on the system or any other problems. And soon I'll decide between VIPRE and Nod32 on the other.
